Showing all, not just paid, posts on homepage
I had a customized theme that I no longer needed to use that only showed the paid posts on the home page. I changed to Edition and was hoping to show all recent posts on the home page, but it is still only showing paid subscriber posts.
I am not sure where in the code to change this and wondered if someone could help me. www.makeroom.fm is the site for reference
It sounds like you may have made a change to your routing. Go to Settings → Labs and download your routes file and share the contents here.
This is the default config for reference:
routes:
collections:
    permalink: /{slug}/
    template: index
taxonomies:
  tag: /tag/{slug}/
  author: /author/{slug}/
routes:
/signup/: members/signup
/signin/: members/signin
collections:
permalink: /{slug}/
filter: visibility:paid
template: index
/blog/:
permalink: /blog/{slug}/
filter: visibility:[members,public]
template: index
taxonomies:
tag: /tag/{slug}/
Filter - Visibility PAID seems to be the thing
Where can I change that?
This will depend a bit on how you want things structured.
Right now, there are two collections.
  1. Homepage that has only paid posts
  2. /blog that has public posts
Do you want everything to just live on the homepage?
The simplest thing is to return to the defaults. Copy the default routes I included above into the routes file and upload them to the same area in Ghost Admin.
Thank you so much! That is what I needed
