I’ve learned a lot about preventDefault(); when trying to figure out why the site reloads when I have a signup-form as full-screen cover greeting unregistered users before they access the site.
It is sneaky because the reload happens behind the full-screen cover, the only hint is that the status messages success/error does not show. Only in Edge/Firefox dev console the reload becomes visible.
Since the site is re-loaded the form is reset, you see the ‘loading’ message flash briefly.
This only happens on GhostPro. Tested it on self-hosted Ghost Docker with nginx proxy, and in my WSL2 Debian node dev env.
Here’s the form when working on Docker/nginx and Ghost local on Node.js
Issue Summary
Two forms active, one in a signup-banner on the site and one in a pop-up full-screen cover. When entering name and e-mail in the full-screen cover the status messages flashes briefly and disappears when submitting the form. Looking at dev console we see that the site is reloaded ‘invisibly’ behind the full-screen cover.
What did you expect to happen? I expect the status messages loading/error/success to be visible after submitting the form, and the user can then continue to the site, hiding the full-screen cover.
Steps to Reproduce
- Load a full screen form with Ghost’s
<form id="fullscreen" data-members-form>and email and name fields, and CSS as below
.fullscreen-cover {
position: fixed;
z-index: 9999;
left: 0;
top: 0;
width: 100%;
height: 100%;
overflow: auto;
background-color: rgb(255,255,255);
color: black;
- Enter name and e-mail and click submit
- loading/error/success messages flashes briefly. Site is reloaded behind the full-screen form. Form is reset, removing the status messages.
Tried this with and without preventDefualt() on the form - same result.
document.querySelector('#fullscreen').addEventListener('submit', function(e) {
e.preventDefault();
Somehow this is GhostPro related, any ideas on how to prevent the reload behind the full-screen cover?
/magnus
Setup information
Ghost Version
Node.js Version
- Debian node.js v18.20.4 dev environment Ghost 5.93.0
- Docker Ghost 5.100.0
- GhostPro 5.105.0-0-gbb9bd0e2+moya
How did you install Ghost?
- Docker Compose & nginx on Debian
- Ghost CLI on Debian
- Localhost uses… Debian in WSL2 and node v18.20.4
- Docker uses ghost/latest on Debian with nginx proxy
- GhostPro…
Browser & OS version
Tried Edge, Firefox on Windows 10 and Linux
Relevant log / error output
Everything works fine, new member invite is sent. Status messages are not displayed since site is re-loaded behind full-screen cover.
Secondary sign-up form on site works fine - status messages OK, no relod.
