I will update this post if/when news comes about
This means DNS (the domain name system) cannot resolve your website’s URL into an IP address, so the web browser is unable to reach it. If you provide the domain name, I can check that it is active, and reachable. You should also check that you have entered the URL correctly and clear the browser’s DNS cache. Furthermore, try changing your DNS servers to 1.1.1.1 and 8.8.8.8.
The domain does not exist, so you’ve either typed the name incorrectly, or not purchased the domain.
Okay, once you’ve resolved this, you’ll need to set up an A record as a minimum that points to the DO instance. You’ll also need CNAME, TXT and MX if you’re using email or Mailgun. Just reply here if you require assistance.
Yeah, I had my A record already setup. No worries IG. I’ll probably just delete the droplet and redo everything. I even have a better idea for the domain name anyway.
