Snippet not showing in dynamic menu
In Using the Editor it says:
To insert a snippet int a new post, use the dynamic menu to select your snippet or type /{snippet title} into a new line of the editor.
  1. I don’t see the snippet in the dynamic menu. I know it’s saved, but I can’t find it.
  2. Tried typing /{snippet title} (obvious changing the text in the brackets) in both an HTML block and a Markdown block, but nothing. In effect:
/{snippet title}
Is what appears on the page. Am I doing this wrong?
@BillBennett you need to remove the brackets. So you just need to type / on a new line and then the first letter of the name of the snippet and you’ll see it pop up in the menu.
This doesn’t work (at least for me). I get a few items in the menu, but no snippets. Tried in different browsers. What comes up are menu items beginning with that letter, but not snippets. Tried with different snippets as well.
