(SOLVED) Edge Theme: editing bookmarks
How can I edit the bookmarks where instead of showing the website title and author (in my case, they’re both my name so it looks off), I include a time stamp of when the page was created instead?
@anelguel, your only option to edit bookmarks is to do so manually by creating your own bookmark card via an HTML card.
I have a snippet set up with the following code:
<figure class="kg-card kg-bookmark-card">
    <a class="kg-bookmark-container" href="LINK_URL">
        <div class="kg-bookmark-content">
            <div class="kg-bookmark-title">TITLE</div>
            <div class="kg-bookmark-description">WRITE-UP</div>
            <div class="kg-bookmark-metadata">
                <img class="kg-bookmark-icon" src="FEATURE_IMAGE_URL">
                <span class="kg-bookmark-author">AUTHOR_NAME</span>
                <span class="kg-bookmark-publisher">PUBLISHER_NAME</span>
            </div>
        </div>
        <div class="kg-bookmark-thumbnail">
            <img src="THUMBNAIL_IMAGE_URL">
        </div>
    </a>
</figure>
There’s a few caveats you should be aware of though.
  1. Don’t ask me why, but the author and publisher fields are reversed and so don’t correspond with their CSS classes. So in the above code, if you wanted to publish an article from the website Radio Ecoshock with the author Jane Doe, your code for the relevant portion would look like this:
<span class="kg-bookmark-author">Radio Ecoshock</span>
<span class="kg-bookmark-publisher">Jane Doe</span>
Note, however, that the formatting will look awry in the editor, but will end up looking correct in the draft/published post.
Editor look:
  1. Due to the manner in which the dot-separator is set up, if you only want to list a publisher but not an author (or vise versa), you’re going to want to insert that info into the publisher field and delete the author field. If you do it the other way around you’ll end up with the dot separator to the right of the lone author field.
Last of all, I add the internal tag #manual-bookmark-card to every post in which I create one or more of these so I can have easy access to a “listing” of all of them, just in case.
Hope that helps. If you’ve got any questions and/or if I’ve missed anything ask away :slight_smile:
This renders beautifully, thank you @Stromfeldt!
Bumping just to check – still no way to edit the bookmark cards? I use them a lot for story lists in two different newsletters, so they show the same publisher each time but DON’T show the tags.
I like the ability to just put in a URL and get the bookmark card. But I’d like to change the format, at least for internal cards.
Thoughts? Perhaps two different bookmark card types? Or the ability for the bookmark card to recognize when it is an internal link versus an external one?
Late update, but I had a client who needed this and so was debugging it.
Replace:
        </div>
With:
    <div class="kg-bookmark-thumbnail" style="min-width: 140px; max-width: 180px; background-repeat: no-repeat; background-size: cover; background-position: center; border-radius: 0 2px 2px 0; background-image: url('YOUR_IMAGE_URL')">
        <img style="display: none;" src="YOUR_IMAGE_URL">
    </div>
That gets the thumbnail image (right side of the card) loading for me in email. I suspect that there’s a fix for the small icon also, but haven’t gotten that working yet.
