I have two URLs: corballis.co.uk and sarahcorballis.co.uk. The latter is not a Ghost site but just a plain old static hmtl site Until a few days ago the latter one worked but the former was very broken and sad. Now, neither works and I suspect it’s something to do with the steps taken to fix the Ghost installation.
This is the error I get if I run curl http://corballis.co.uk:
LibreSSL SSL_connect: SSL_ERROR_SYSCALL in connection to [www.corballis.co.uk:443](http://www.corballis.co.uk:443/)
and in the nginx error log, I get:
[error] 21542#21542: *1 no “ssl_certificate” is defined in server listening on SSL port while SSL handshaking, client: 192.168.178.1, server: 0.0.0.0:443
Next, I tried to create ssl certs using certbot but he challenges fail:
Performing the following challenges:
http-01 challenge for [corballis.co.uk ](http://corballis.co.uk/)
http-01 challenge for [sarahcorballis.com](http://sarahcorballis.com/)
http-01 challenge for [www.corballis.co.uk ](http://www.corballis.co.uk/)
http-01 challenge for [www.sarahcorballis.com](http://www.sarahcorballis.com/)
Waiting for verification…
Challenge failed for domain [sarahcorballis.com](http://sarahcorballis.com/)
Challenge failed for domain [corballis.co.uk ](http://corballis.co.uk/)
Challenge failed for domain [www.corballis.co.uk ](http://www.corballis.co.uk/)
Challenge failed for domain [www.sarahcorballis.com](http://www.sarahcorballis.com/)
Cleaning up challenges
Some challenges have failed.
IMPORTANT NOTES:
* The following errors were reported by the server:Domain: [sarahcorballis.com](http://sarahcorballis.com/)
Type: connection
Detail: Fetching
http://sarahcorballis.com/.well-known/acme-challenge/xxxx
Connection refusedDomain: [corballis.co.uk ](http://corballis.co.uk/)
Type: connection
Detail: Fetching
http://corballis.co.uk/.well-known/acme-challenge/xxxx
Connection refusedDomain: [www.corballis.co.uk ](http://www.corballis.co.uk/)
Type: connection
Detail: Fetching
[http://www.corballis.co.uk/.well-known/acme-challenge/xxxx: ](http://www.corballis.co.uk/.well-known/acme-challenge/xxxx:)
Timeout during connect (likely firewall problem)Domain: [www.sarahcorballis.com](http://www.sarahcorballis.com/)
Type: connection
Detail: Fetching
http://www.sarahcorballis.com/.well-known/acme-challenge/nxxxx
Timeout during connect (likely firewall problem):
So, I ran wget on localhost twice and can see that I’m getting a 301 redirect, though I can’t find a return or rewrite in the nginx config file so that’s confusing
Here’s the output running wget on localhost:2368
–2021-01-02 20:30:03-- [http://localhost:2368/ ](http://localhost:2368/)
Resolving localhost (localhost)… ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:2368… failed: Connection refused.
Connecting to localhost (localhost)|127.0.0.1|:2368… connected.
HTTP request sent, awaiting response… 301 Moved Permanently
–2021-01-02 20:30:03-- https://localhost:2368/
GnuTLS: An unexpected TLS packet was received.
Unable to establish SSL connection.
and here it is when running wget on localhost:80
–2021-01-02 20:24:39-- http://localhost/
Connecting to localhost (localhost)|::1|:80… connected.
–2021-01-02 20:24:39-- https://localhost/
Connecting to localhost (localhost)|::1|:443… connected.
GnuTLS: The TLS connection was non-properly terminated.
Not much difference there but when I run wget localhost:443 then I get
HTTP request sent, awaiting response… Read error (Connection reset by peer) in headers.
Retrying.
(It retries 20 times before giving up)
My guess is there’s a redirect from port 80 to 443. This is a good idea if ssl is up and running but would seem to be a bad idea when it’s not because it (and this is a guess) means certbot can’t do a successful challenge as it is rerouted to 443 which isn’t yet working. So, I think (gues, prey) that the thing is to track down how the redirect is occurring and temporarily disable it. But a search for "res.redirect" on my system literally throws up hundreds of responses so I wouldn’t know where to start.
One final point to note is that in desperation, I did create a new directory earlier on and did a ghost install local which produced a development site that worked. I have since deleted that but I wonder if it made a change somewhere that is causing the issue? Again, just a guess.
Here is the output of nginx -T
nginx: the configuration file /etc/nginx/nginx.conf syntax is ok
nginx: configuration file /etc/nginx/nginx.conf test is successful
configuration file /etc/nginx/nginx.conf:
user www-data;
worker_processes auto;
pid /run/nginx.pid;
include /etc/nginx/modules-enabled/*.conf;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
server_tokens off;
server_names_hash_bucket_size 64;
# server_name_in_redirect off;
include /etc/nginx/mime.types;
default_type application/octet-stream;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Next two lines added by me on 2 Jan 2021 to try and resolve Cloudflare 521 issue
# (successful but replaced by current issue)
ssl_client_certificate /etc/nginx/ssl/cloudflare.crt;
ssl_verify_client on;
# Logging Settings
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
# Gzip Settings
gzip on;
gzip_disable "msie6";
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
# gzip_types text/html text/plain text/css image/*;
# Virtual Host Configs
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*;
configuration file /etc/nginx/modules-enabled/50-mod-http-auth-pam.conf:
load_module modules/ngx_http_auth_pam_module.so;
configuration file /etc/nginx/modules-enabled/50-mod-http-dav-ext.conf:
load_module modules/ngx_http_dav_ext_module.so;
configuration file /etc/nginx/modules-enabled/50-mod-http-echo.conf:
load_module modules/ngx_http_echo_module.so;
configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
configuration file /etc/nginx/modules-enabled/50-mod-http-image-filter.conf:
load_module modules/ngx_http_image_filter_module.so;
configuration file /etc/nginx/modules-enabled/50-mod-http-subs-filter.conf:
load_module modules/ngx_http_subs_filter_module.so;
configuration file /etc/nginx/modules-enabled/50-mod-http-upstream-fair.conf:
load_module modules/ngx_http_upstream_fair_module.so;
configuration file /etc/nginx/modules-enabled/50-mod-http-xslt-filter.conf:
load_module modules/ngx_http_xslt_filter_module.so;
configuration file /etc/nginx/modules-enabled/50-mod-mail.conf:
load_module modules/ngx_mail_module.so;
configuration file /etc/nginx/modules-enabled/50-mod-stream.conf:
load_module modules/ngx_stream_module.so;
configuration file /etc/nginx/mime.types:
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
configuration file /etc/nginx/sites-enabled/corballis.co.uk:
server {
listen 80;
listen [::]:80;
listen 443 ssl;
listen [::]:443 ssl;
server_name corballis.co.uk www.corballis.co.uk;
root /var/www/corballis.co.uk/system/nginx-root;
location / {
location ~ /.well-known {
allow all;
client_max_body_size 50m;
configuration file /etc/nginx/sites-enabled/sarahcorballis.com:
server {
listen 80;
listen [::]:80;
listen 443 ssl;
server_name sarahcorballis.com www.sarahcorballis.com;
root /var/www/sarahcorballis.com/;
index index.html;
try_files $uri $uri/ /index.html;
allow all;
I was serving the site using Cloudflare but have temporarily paused Cloudflare on both sites whilst I try to get to the bottom of the current issue.
