What version of Ghost are you using? Latest version
I don’t want the news letters but just to send invites and what not through or in-house email server. The config section is set correctly but it still is kicking an error:
Knowing what the error is might help, please post the error in your log.
Though, I’m willing to bet you’ll need to modify the port and secure line to this, and include the requireTLS
Inside the admin site, I resend an invite and get “Please verify your email settings” and the ghost log shows:
[2026-04-27 13:03:39] WARN Error sending email: Failed to send email. Reason: Sendmail exited with code 67. Please check your email settings and resend the invitation.
[2026-04-27 13:03:39] ERROR “POST /ghost/api/admin/invites/” 500 946ms
MESSAGE: Error sending email: Failed to send email. Reason: Sendmail exited with code 67. Please check your email settings and resend the invitation.
level: normal
“Please see Configuration - Ghost Developer Docs for instructions on configuring email.”
Error: Sendmail exited with code 67
at createMailError (/var/www/ghost/versions/6.26.0/core/server/services/mail/ghost-mailer.js:90:12)
at ChildProcess. (/var/www/ghost/versions/6.26.0/node_modules/nodemailer/lib/sendmail-transport/index.js:142:27)
at Object.onceWrapper (node:events:639:26)
at ChildProcess.emit (node:events:524:28)
at ChildProcess._handle.onexit (node:internal/child_process:293:12)
On this same system, I also run several servers that does including our new VCS site.
