Stripe Integration Documentation Innacuracy
On the Stripe Integration Page it has this:
Connect to Stripe
Head over to SettingsPayments and open your Stripe settings…
But now it’s Settings → Membership → Premium → Connect Stripe
(it may not be “connect stripe” now, since I’ve connected I don’t see the option any more)
Why is this important? I hunted around for a couple days through documents trying to figure out how to enable the stripe integration, since it clearly wasn’t under Settings → Payments.
Paging @RyanF - looks like the docs need updating here! :)
Thanks for flagging! Will put it on my list to update.
Thanks @RyanF !!!
Appreciate all the work you guys are doing!
