- What’s your URL? www.keplerobotics.in
- What version of Ghost are you using? 3.17.1
- What configuration? Production with https
- What errors or information do you see in the console? None
- What steps could someone else take to reproduce the issue you’re having? I cannot currently keep the website down as it’s a client’s website. But basically when converted to https the website will redirect to localhost
I am using the binami aws ghost image. When I setup https with Let’s Encrypt I saw that in pages with images I get mixed content warning. So after a bit of reading I saw you also have to change the url to https one. So after I did that the website redirects to localhost.
And I found that the solution was to setup a x-forwardes-proto header. But I am confused in where to do that. Although after a bit of reading I have added to the conf files which I think is the correct one, it’s still not working.
Here are the conf files:
htttp-app.conf
Include “/opt/bitnami/apps/ghost/conf/banner.conf”
ProxyPass /bitnami !
ProxyPass / http://127.0.0.1:2368/
ProxyPassReverse / http://127.0.0.1:2368/
htttp-prefix.conf
# Include file
RewriteEngine On
RewriteCond “%{HTTP_HOST}” ^ec2-([0-9]{1,3})-([0-9]{1,3})-([0-9]{1,3})-([0-9]{1,3})...amazonaws.com(:[0-9])?$
RewriteRule “^/?(.*)” “%{REQUEST_SCHEME}://%1.%2.%3.%4%5/$1” [L,R=302,NE]
Include “/opt/bitnami/apps/ghost/conf/httpd-app.conf”
htttp-vhosts.conf
<VirtualHost *:80>
ServerName ghost.example.com
ServerAlias www.ghost.example.com
DocumentRoot “/opt/bitnami/apps/ghost/htdocs”
Include "/opt/bitnami/apps/ghost/conf/httpd-app.conf"
RequestHeader set X-Forwarded-Proto "http" # I added this line
<VirtualHost *:443>
SSLEngine on
SSLCertificateFile “/opt/bitnami/apps/ghost/conf/certs/server.crt”
SSLCertificateKeyFile “/opt/bitnami/apps/ghost/conf/certs/server.key”
RequestHeader set X-Forwarded-Proto "https" # I added this line
