Site Audit report showing “There is no h1 tag on the webpage” (My blog posts). How to fix that issue?
I couldn’t make heads or tails of your screenshot.
What version of Ghost, what database, and what theme?
Is this a new Ghost install? If so, how did you install?
This screenshot is site-audit report. Ghost is latests updated. Not new install. Earlier i used liebling theme. It showed me same problem. Hosted in digitalocean.
That’s likely to be a theme-specific problem, since the theme controls much of the page markup.
Liebling theme uses the post title as the H1 by default. Can you share a link to your blog post?
Now I’m using Simply theme. Here is the Link - Tedknow
There’s an H1 tag on the post, so the audit tool is off.
Yes, I think so. Thank you! ![]()
