I’m close here, I can feel it!
I’m trying to add a new homepage section between the “cover” and “featured posts” section, instead of creating a brand new homepage from scratch.
The new section is going to just be a simple “countdown” widget for fundraising that looks like this:
I’ve got a new file in partials area of my file manager with the following code:
<section class="counter">
<div id=countdown-wrap>
<div id="goal">$300k Goal</div>
<div id="glass">
<div id="progress">
</div>
</div>
<div class="goal-stat">
<span class="goal-number">17%</span>
<span class="goal-label">Funded</span>
</div>
<span class="goal-number">$51k</span>
<span class="goal-label">Raised</span>
</div>
<span class="goal-number"><div id="countdown"></div></span>
<span class="goal-label">Days to Go</span>
</div>
<span class="goal-number">3</span>
<span class="goal-label">Company Sponsors</span>
</div>
</div>
</section>
Step 2 was adding the css in the “misc” folder like this:
.counter {
font-family: "Modern", sans-serif;
box-sizing: border-box;
.counter {
background-color: #fff;
#countdown-wrap {
width: 100%;
height: 300px;
/* border: 1px solid black; */
padding: 20px;
max-width: 650px;
margin: 50px auto 50px;
#goal {
font-size: 48px;
text-align: right;
color: #333333;
@media only screen and (max-width: 640px) {
#goal {
text-align: center;
#glass {
width: 100%;
height: 20px;
background: #c7c7c7;
border-radius: 10px;
float: left;
overflow: hidden;
#progress {
float: left;
width: 17%;
height: 20px;
background: #ffbc2e;
z-index: 333;
/* border-radius: 5px; */
.goal-stat {
width: 25%;
padding: 10px;
float: left;
margin: 0;
color: #333333;
.goal-stat {
width: 50%;
text-align: center;
.goal-number,
.goal-label {
display: block;
.goal-number {
font-weight: bold;
And finally dropped in the js in a new file in “lib” folder:
var counter = "counter";
CountDownTimer('8/1/2023 10:1 AM', 'countdown');
CountDownTimer('5/1/2023 10:1 AM', 'newcountdown');
function CountDownTimer(dt, id)
var end = new Date(dt);
var _second = 1000;
var _minute = _second * 60;
var _hour = _minute * 60;
var _day = _hour * 24;
var timer;
function showRemaining() {
var now = new Date();
var distance = end - now;
if (distance < 0) {
clearInterval(timer)};
document.getElementById(id).innerHTML = '0';
return;
var days = Math.floor(distance / _day);
var hours = Math.floor((distance % _day) / _hour);
var minutes = Math.floor((distance % _hour) / _minute);
var seconds = Math.floor((distance % _minute) / _second);
document.getElementById(id).innerHTML = days /*+ ' days'*/;
//document.getElementById(id).innerHTML += hours + 'hrs ';
//document.getElementById(id).innerHTML += minutes + 'mins ';
//document.getElementById(id).innerHTML += seconds + 'secs';
timer = setInterval(showRemaining, 1000);
</script>
Now I’m stumped. The html is rendering when I insert the new partial template block in my default.hbs, but no css and no js to be found!! Here’s some options I think might be the problem:
- I’m hoping I just screwed up some references (all the files are counter.hbs, counter.css and counter.js)
- I didn’t put the files in the correct folders to be picked up properly… maybe I should add the .js code into the main.js file??
- Who knows?
Any help is much appreciated! I really think this could be a great use case/explainer eventually for others as an easy way to drop in a new homepage section, but I’m not an expert coder by any means. THANK YOU
