I’ve followed the instructions to download and setup Pico from Github, but even after uploading the routes.yaml I am still left seeing my previous theme (even though it says the zipped theme from Github is active). Any advice?
Restart the Ghost, clear your cache? If you’re on Ghost Pro you might have to ask support to clear the cache there – I’ve had to do this on occasion.
Hello.
I just wanted to add that I have exactly the same problem even after resetting Ghost. Any other solution.
— G.
FYI — The Pico theme directory is titled Lyra when I download and unzip it.
Ok. I think I solved the problem. The link in Github that says ‘1. Download this theme’ actually links to a non-functioning theme called Lyra. If you download Pico using the standard Github link on the top right you should be in business.
— G.
@gmansf perhaps something is awry with your .zip…
The Pico-master.zip should unzip as a folder with the same name, Pico-master
Try re-downloading it from here: GitHub - TryGhost/Pico: A paid members publishing theme for Ghost
