I was trying to upgrade from version 3.something (sorry I didn’t grab the version I was on) to 4.4.0. I did receive error messages but thought I had worked through them based on feedback wihin the upgrade error messages. However, now my ghost server won’t start up. Error message below.
- https://infosec.theos-blog.com/
- What version of Ghost are you using?
4.4.0 - What configuration?
OS: Ubuntu, v20.04.2 LTS
Node Version: v14.16.1
Ghost Version: 4.4.0
Ghost-CLI Version: 1.17.1 - What browser?
Firefox 88.0 on Mac OS X - What errors or information do you see in the console?
not-ghost@ghost-new-s-1vcpu-2gb-nyc1-01:/var/www/ghost$ cat /home/not-ghost/.ghost/logs/ghost-cli-debug-2021-05-09T21_47_03_717Z.log
Environment: production
Command: ‘ghost restart’
Message: Ghost was able to start, but errored during boot with: alter tablemembers_productsadd constraintmembers_products_member_id_foreignforeign key (member_id) referencesmembers(id) on delete CASCADE - UNKNOWN_CODE_PLEASE_REPORT: Referencing column ‘member_id’ and referenced column ‘id’ in foreign key constraint ‘members_products_member_id_foreign’ are incompatible.
Help: Error occurred while executing the following migration: 02-add-members-products-table.js
Suggestion: journalctl -u ghost_infosec-theos-blog-com -n 50
Stack: Error: Ghost was able to start, but errored during boot with: alter tablemembers_productsadd constraintmembers_products_member_id_foreignforeign key (member_id) referencesmembers(id) on delete CASCADE - UNKNOWN_CODE_PLEASE_REPORT: Referencing column ‘member_id’ and referenced column ‘id’ in foreign key constraint ‘members_products_member_id_foreign’ are incompatible.
at Server. (/usr/lib/node_modules/ghost-cli/lib/utils/port-polling.js:73:28)
at Object.onceWrapper (events.js:421:28)
at Server.emit (events.js:315:20)
at emitCloseNT (net.js:1659:8)
at processTicksAndRejections (internal/process/task_queues.js:79:21) - What steps could someone else take to reproduce the issue you’re having?
Attempt to upgrade from 3.something to 4.3.3.
ghost doctor output:
not-ghost@ghost-new-s-1vcpu-2gb-nyc1-01:/var/www/ghost$ ghost doctor
Checking system Node.js version - found v14.16.1
Checking logged in user
Ensuring user is not logged in as ghost user
Checking if logged in user is directory owner
Checking system compatibility
Checking for a MySQL installation
- sudo systemctl is-active ghost_infosec-theos-blog-com
? Sudo Password [hidden] - sudo systemctl reset-failed ghost_infosec-theos-blog-com
Validating config
Checking folder permissions
Checking file permissions
Checking memory availability
Checking binary dependencies
Checking free space
Checking systemd unit file
Checking systemd node version - found v14.16.1
