Truncate post, add "read more" link on home page
I’d like to show only 300 or so words of the main post on my home page so it doesn’t take over the entire space, and then add a “Continue Reading” hyperlink. Is that possible? I’m using a custom Source version with a single story in the center header. Currently I have {{content}} but I’d like to truncate it. {{excerpt}} is not what I want.
The {{content}} helper has a words param, e.g. {{content words="300"}} :slight_smile:
Yay thank you!!! I knew there was an easy answer but don’t always know where to find them :)
Hello, I would like to do the same thing, and then also add a “Continue Reading” hyperlink on my homepage. How do I manage to add this link, so it is visible on the homepage? Thanks a lot in advance!
I can’t remember the final solution, but I did end up doing it. ChatGPT helped me… and while I did it via editing the theme files, I bet you can do it via code injection. Check out our homepage at www.burlington.buzz to see how it’s executed.
Thanks a lot Nicci! Your page looks great
