I have two domains for the same brand name. https://androidwedakarayo.com and https://androidwedakarayo.lk
Now I am running with https://androidwedakarayo.com and I want to load my site with https://androidwedakarayo.lk also.
Is it possible and how to do it?
inoryum
September 22, 2020, 5:22pm
2
Are you gonna use same contents for 2 domains? if so its better to use a permanent redirect.
But alternatively you can point your second domain to first domain via CNAME on second domain adjust the dns as follow
Record type CNAME
Host @ or Blank
Value: androidwedakarayo.com
& remove any A record added against the root domain
Sitemap is not loading with the secondary domain. Its loaded only with .com domain. How to resolve it?
inoryum
September 22, 2020, 6:08pm
6
It cant be loaded with the second domain as ghost itself declared the fisrt domain in its config
How to do it. Sorry I am not a geek.
inoryum
September 22, 2020, 6:12pm
8
Hey sorry misstyped … its Cant not can
Oh I see. Is it possible to create a custom sitemap and load it with the secondary domain?
inoryum
September 22, 2020, 7:42pm
10
Yes its possible by creating a sitemap manually & then add it but it is bit tricky & involves some config on your nginx server block…
Since you are using one instance for two domains the better option is to redirect to a specific domain…
In my case i was using my blog at blog.mydomain.com but decided to use my main domain (domain.com ) to host the blog … so I did a redirection instead of cname setup…
No if users type for a blog post something like blog.mydomain.com/post-url & it gets redirected to mydomain.com/post-url permanently
This way I am not duplicating my own contents which is good for SEO
