Www or rootdomain - which is better?
I’ve just set up my custom domain using Ghost Pro and GoDaddy but limited to www
Does anyone have solid advice on benefits / cons of each approach?
Personal choice. There’s no advantage of one over the other. Because www and naked domains are essentially separate domains (sites), use one only, and redirect non-www traffic to www if that’s what you’re using.
Hey, so I am using GoDaddy and it doesn’t support rootdomain DNS config according to the Ghost help pages.
Therefore my site is currently defaulting to www. In the address bar.
If I wanted to default to domain.tld instead can I do a 301 redirect from www to domain?
Stick with www or change the nameservers to Cloudflare or similar, so you can use a naked domain.
However, I’d have thought the A record could be set to the IP provided by Ghost Pro, and you could delete the CNAME for www.
Interesting idea… although the help documentation seems to say the A record is optional and CNAME is mandatory :(
I was also considering cloudflare but then I wondered why would I do that when Ghost Pro which has CDN, DDos already included?
I don’t really know much about the benefits of Cloudflare to be honest - if that’s a good thing to do maybe I’ll try it
Hey there, What did you do about this in the end? I’m in the same boat, I want the root domain but just found out GoDaddy doesnt support it, which seems really lame.
I transferred my domain to cloudflare in the end and was able to use the root domain that way
