Two SEO- questions about Ghost as headless CMS
If I set up Ghost in AWS static ip xxx.xxx.xxx and use API to pull content to React app hosted in exampledomain.com, is there a possibility for double indexing in Google because the same content is in two pages? Or can I
Set the Ghost page as private?
Is it possible to pull all the metadata etc seo-related also to the React app?
Sorry about the noob questions!
Yo @miika! You can check out everything that is available in the Content API over here in our docs:
Ghost has a private option which will prevent the site from being indexed :slight_smile:
Thank you!
