+ sudo systemctl is-active ghost_guru61-com
✔ Validating config
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking systemd unit file
✔ Checking systemd node version - found v16.19.0
+ sudo systemctl start ghost_guru61-com
+ sudo systemctl stop ghost_guru61-com
✖ Starting Ghost: guru61-com
A GhostError occurred.
Message: Could not communicate with Ghost
Suggestion: journalctl -u ghost_guru61-com -n 50
OS: Ubuntu, v18.04.6 LTS
Node Version: v16.19.0
Ghost Version: 5.37.0
Ghost-CLI Version: 1.24.0
Environment: production
Command: 'ghost start'
Additional log info available in: /home/root2/.ghost/logs/ghost-cli-debug-2023-03-07T13_45_35_443Z.log
root2@linux:/var/www/guru61_com$ ghost doctor
https://careers.ghost.org
✔ Checking system Node.js version - found v16.19.0
✔ Checking logged in user
+ sudo systemctl reset-failed ghost_guru61-com
✔ Validating config
✔ Checking free space
root2@linux:/var/www/guru61_com$ ghost restart
Hmm, is that a docker site? Or that is a pretty new Ghost install?
What ghost doctor says?
