Does anyone have experience with Node snap package on Ubuntu with Ghost installation? (It might not be recommended?)
I have done a Ghost upgrade and Node.js needed to be upgraded to a newer version than Ubuntu provided on the current package manager.
I had a look at the snap package option for node. It seemed to be quite a good option (to me) for managing node versions. (Simple install and remove commands etc)
Examples:
sudo snap install node --classic
OR
sudo snap install node --channel=18/stable --classic
So I decided to give it a go for my ghost installation. (I got backup and snapshot to roll back my changes)
Installation Information:
OS: Ubuntu, v22.04.4 LTS
Node Version: v20.14.0
Ghost Version: 5.82.12
Ghost-CLI Version: 1.26.0
Environment: production
Command: ‘ghost doctor’
After I did the upgrade to Node v20.14.0, I ran ghost doctor.
Ghost Doctor Results:
Checking system Node.js version - found v20.14.0
Checking logged in user
Ensuring user is not logged in as ghost user
Checking if logged in user is directory owner
Checking system compatibility
Checking for a MySQL installation
- sudo systemctl is-active ghost_****************-co-uk
Validating config
Checking folder permissions
Checking file permissions
Checking memory availability
Checking binary dependencies
Checking free space
Checking systemd unit file
Checking systemd node version
One or more errors occurred.
- SystemError
Message: Unable to determine node version in use by systemd
Help: Ensure ‘ExecStart’ exists in /lib/systemd/system/ghost_*********-co-uk.service and uses a valid Node version
I then changed the file as requested.
Old Config:
[Unit]
Description=Ghost systemd service for blog: ***********-co-uk
Documentation=Ghost: The #1 open source headless Node.js CMS
[Service]
Type=simple
WorkingDirectory=/var/www/ghost
User=999
Environment=“NODE_ENV=production”
ExecStart=/usr/bin/node /usr/bin/ghost run
Restart=always
[Install]
WantedBy=multi-user.target
New Config:
[Unit]
Description=Ghost systemd service for blog: ************-co-uk
[Service]
Type=simple
User=999
ExecStart=/snap/bin/node /usr/bin/ghost run
Restart=always
[Install]
Current State
I then tried to run ghost doctor and got the same issue, which has confused me.
I have rebooted the server just encase it needed services restarted but still the same issue sadly.
If anyone has any advice or additional information, I would be much appreciated. I will do my own research and will try to update this forum post If I find anything.
Thanks for taking the time to read this post.
