What size and aspect ratio look best in featured post lists
I’m using a modified Caspar theme for a site and trying to figure out what size and aspect ratio of image works best for a post so it looks good when it appears as a featured post. Portrait is clearly a no go as we see multiple ‘beheadings’. We rely on photographs so if we know what to ask for it would be useful.
thanks
ps - if viewing the site would be helpful it’s here https://sisracing.tv
For the modified Caspar theme, a landscape orientation works best for featured post images to avoid cropping issues like “beheadings.” Try using images with a 16:9 aspect ratio, ideally around 1200x675 pixels. This size maintains good resolution across devices and minimizes unwanted cropping. Check how images display in both desktop and mobile views, as sometimes slight adjustments can improve the layout further.
Cheers Anam, appreciate the input.
thanks
