That part has been working fine. But now this weird bar shows up on the top and the icon isn’t hidden. Possible it’s related to filling out the facebook card info?
Wave theme fyi. Anyone able to help me solve this mystery?
Looks like if you set the og_description, it’ll try to render the player. So… don’t set the facebook description in the meta data, or edit the theme to tweak the behavior so that this doesn’t happen.
I meant one that you add. Themes can’t secretly tag things. :) But that’d be a good way to trigger the playlist behavior on ONLY the posts where you want it.
Agreed, it would have been easier than hijacking the FB metadata.
Since you’re so good at this (sorry to ask you to be my personal tech support), is there an obvious place in the Wave code I should look to see if I can undo this functionality?
