Why doesn't Highlighting work?
Hey everyone,
I just started a free trial to see how I like Ghost 2.0. I just created my first publication and and everything seems to work except highlighting text.
I try to use ==text== but it doesn’t highlight anything. Also, don’t know if I can highlight using the new editor.
Any help would be great if I’m missing something. I’m just doing ==text== to try and highlight words.
Highlights are not part of the actual Markdown spec, they’re a sometimes-used addition which varies depending on where you write. Should work inside a Markdown card, however.
Do you mean that?
If so, check out how it’s done here.
P.S. — At the top of the post, you will see where to find markdown’s source.
Cheers!
