After setting up a custom URL, it seems to default to www when sharing. Is there a way to remove the www so that it’s just the domain name? The www seems a bit clumsy and outdated.
You’d need to edit your dns to switch the an and cname records, then reactivate in the control panel, if you’re on Ghost Pro.
If you’re self hosting, you’ll reconfigure ghost to use the naked version of the domain, and restart.
Incorrect, most legit sites are still www but with cname redirect for lazy typers. Also www is better form for inevitably if you choose to add a shop or use the domain for any other purpose.
