Fill out the following bug report template with as much detail as possible!
Are you sure this is a bug? If you just need help, post in the developer help category. If it’s a feature request, head to the ideas category.
Issue Summary
- Explain roughly what’s wrong When attempting to tip/donate using chinese Yuan it gives you an error via the website
- What did you expect to happen? Donation should of redirected to stripe but instead showing the error
Steps to Reproduce
- Set Donation Currency Link To CNY
- Add the link to navigation or page
- Navigate to site and attempt to donate
Setup information
Ghost Version
5.0
Node.js Version
If self-hosting - share which version of Node.js you’re using.
How did you install Ghost?
Host provider installed for me
Linux
Database type
MySQL 5.7
Browser & OS version
IOpera Windows 10
Relevant log / error output
NA
I believe Stripe does NOT allow chinese currency to be used within its website and it may be blocked. This is a good reminder to possibly remove the option for Yuan currency.
