Accessing Ghost over localhost fails because of https redirect
Hello,
before publishing a Ghost site, I’m trying to work with Ghost over localhost, before allowing access to it over my reverse proxy. The problem I seem to be having is that Ghost keeps trying to redirect my browser’s localhost requests to https, which causes the connection to error out. How can I configure Ghost not to forward http requests to https? When the site is public, I will have my reverse proxy configured to do that anyway, and I really don’t see the benefit of https on localhost, especially since Ghost can’t even seem to complete the TLS handshake.
  • What’s your URL? This is the easiest way for others to help you
    Site not public yet
  • What version of Ghost are you using? If it’s not the latest, please update Ghost first before opening your topic
    6.24.0
    Official Docker Compose
    Same versions as included in the official compose file.
ghost-1  | [2026-03-27 16:50:18] INFO "GET /" 301 5ms
ghost-1  | [2026-03-27 16:50:30] INFO "GET /" 301 2ms
  1. Install Ghost using the Docker Compose method.
  2. Configure .env and docker-compose.yml, but do not enable a reverse proxy.
  3. Try accessing Ghost over localhost.
  4. See TLS handshake errors - SSL_ERROR_RX_RECORD_TOO_LONG caused by Ghost attempting to redirect http://localhost:2368 to https://localhost:2368/.
Any help is greatly appreciated.
The solution ended up being changing:
url: https://${DOMAIN:?DOMAIN environment variable is required}
to
url: http://${DOMAIN:?DOMAIN environment variable is required}
in my compose file. And adding
DOMAIN=localhost:2368
to my .env,
