Adding card (code block, embedded HTML) into ordered list not possible
Hi folks,
I’m trying to add a card (code block (```) or embedded HTML (Gist)) into a ordered list. Is that the expected behavior?
Preview: Use Azure Artifacts outside of Visual Studio
Thanks & BR
Christoph
@peterschen yes that’s expected, if you need nested lists or list items containing structural elements such as code blocks then you can use a markdown or html card
Why didn’t I think of that. Thanks!
