Is there an Android Client for writing? I can’t find any Markdown editor with ghost upload.
I have the same question, it appears the Android app is no longer supported. Are there any alternatives?
You may want to consider iA Writer
Website:
Play Store:
Ghost integration:
IA Writer has no integration of ghost with the Android version. The IOS Version has it.
Thats unfortunate. I thought the feature set would be the same. In that case, it really is a concern for the android platform.
