A while back, a button popped up in the posts area to create some sort of filter. Now, I cannot get rid of it anymore.
It’s annoying to always have it in the way. Does anyone know how to get rid of it?
Had same issue. Since I am self-hosting it I was able to connect directly to the database and drop the record from the table. Probably somewhere here in this forum found which table to update.
I would say that it’s more like a bug. System shouldn’t allow to do this. Or should give an easy way to remove created filter(s)
If you select the “Hello”, you will see an icon appear alongside the “New post”. Click the icon, you will get the delete option.
When I click on the “Hello” sidebar view, it always opens “Published.” There’s no button to remove the filter there.
That is true, when you create a filter for already existing filter (built-in) then you’ll never see the config option. I had the same for Drafts.
The bug is minor, but super annoying.
Hi @john1
BTW I found that post which helped me. That is only solution that I have.
As we see that bug is pretty old, from 2022.
And again, you should have access to the database. It means that you should self-host your blog for that type of access
I don’t know if it’s even possible for the cloud version
Perfect, worked like a charm!
I just came across this same bug - but I’m on Ghost(Pro), not self-hosted. Has anyone come up with a solution?
