Anyone using local LLM with Ghost Blog?
I wonder if there are other people using open source LLM with Ghost Blog.
I’m currently using Qwen 3.5 9B LLM on my RTX 4070 to “prepare” common elements when I’m posting; it helps me avoid having to leave another place of an older post open to copy and paste callouts, and common elements that I use across my posts.
I also use the same LLM to do vision descriptions and also translate EN to ES and PT-BR as initial placeholder versions (which later I use ChatGPT 5.5 to translate to a better version).
Anyone doing something similar? I know we can do with SOTA models but I’m pushing the limits with smaller LLM as much as possible to allow Portability, Privacy, Digital Sovereignty.
It would be great to hear other similar folks.
B
I have not wired Ghost to a local model myself, but for the jobs you describe — callout scaffolding, vision alt-text, and EN→ES/PT placeholders — a cloud API fallback is usually cheaper than it looks if you keep the model small. Anthropic’s Haiku 5.5 list price is $0.10 per million input tokens and $0.50 per million output under 100K prompts (cache reads $0.01/M), so a few hundred tokens of boilerplate per post is fractions of a cent; the bill only jumps when you send long HTML bodies or high-res images every time. Local Qwen on a 4070 still wins for privacy and offline drafts; if you ever A/B against an API, log input vs output tokens per post type so you can see whether the GPU time or the per-token meter is actually cheaper for your mix.
