Best way to export Ghost story to markdown?
Should I just write the whole post in a markdown card and copy to export it? Or does better ways exist?
I found this website which converts an URL http://heckyesmarkdown.com, but I wanted to know if there is some better alternative?
This is for an external story to be published on another website.
@MLFromScratch heckyesmarkdown.com sounds like a reasonable tool for the job if it’s a one-off, there are likely similar ones available all based on different underlying parsing/stringifying libraries.
https://unifiedjs.com is a really good go-to resource for doing this sort of thing if you’re a coder :) If you wanted markdown-formatted versions of all your content you could take the html value of posts via Ghost’s Content API and put them through a rehype.parse -> remark.stringify pipeline to get a markdown version (there’s a specific plugin for that).
Thanks Kevin, this looks good. This is most probably the first of many times I will need to export.
I’m not sure there is an advantage to the rehype plugin though, why would it be better? :slight_smile:
That comment was focused on tools to build an automated pipeline if this was something you needed to do for every post.
@MLFromScratch You probably already found a solution, but for anyone else who has the same question, I wrote a simple script that uses the Ghost API and pandoc to save posts as markdown:
