Bitcoin payments
I’m a little confused with this.
Following on from @Cathy_Sarisky, does this follow the same workflow as the current Ghost flow does? It seems to be tacked onto the side - even the selection of the account/tier.
What happens if the user doesn’t want to use Crypto at first, but then half way through the process does, what happens then?
How to create the tiers without connect stripe?
You can enable a system like GitHub - lukeprofits/Monero_Subscriptions_Wallet: A Monero wallet that automatically pays subscriptions.
There is no limitations related to crypto on this.
BTCPay is currently supported. The integration honestly it’s not the better but it seems to work.
Devs called the core issue is the hard Stripe dependance on Ghost. Anyways, here is the integration:
I’m testing it and I will share my experiments.
