Blog on Shopify vs Ghost for SEO
Hello,
Hoping someone can give some advice here.
We currently have a Shopify store but not a blog to back it up, what’s your opinion on having a Ghost blog embedded into our Shopify store VS having the blog directly feed from Shopify.
We’d love to use ghost for blogging and embed it into our store but we are afraid this will negatively affect our overall SEO ranking on our Shopify store.
Do we blog direct using Shopify or go with the Ghost theme and embeded the page?
Another reason we don’t want to use Shopify is that their blogging templates suck!
Thoughts?
Thanks for your time.
Ashley
I had this same dilemma. Shopify is fantastic at e-commerce but subpar when it comes to their blogging features.
You could always use ghost blog as a subdomain but SEO gurus will tell you that subdomains are less effective for sharing authority / ranking juice to the root domain.
honestly, just keep it on the shopify side and try your best with working on the design of the templates.
Remember that a simplistic/minimalistic theme can do wonders so as long as you can get something like that, don’t worry too much about the design.
IMHO that is better than having a subdomain, in any case, good luck however you end up doing it!
Hi Ashley,
I would suggest you stick with Shopify as there is none better than shopify for e-commerce store if you really want to add ghost theme, go for a sub domain but its not that good for SEO point of view. You may customize your existing theme also
Have a look at this example https://pccustombuilder.com/
Ghost’s SEO tools are comprehensive enough for basic optimization, but they are less extensive than some of its competitors.
My opinion is that it is better to use Ghost and embed it into your Shopify store. This way, you will have complete control of the content and design of your blog, allowing you to create a unique and engaging experience for your readers. Additionally, embedding Ghost into your Shopify store will not negatively affect your SEO ranking. In fact, having an optimized blog can help you to increase your rankings and reach a wider audience.
looks like somebody in the valley heard you ;)
I’m wondering, if it would be possible to create a Shopify app that embeds a Ghost blog? Or even headless Ghost using the Shopify theme?
It’s absolutely possible using the Ghost Content API:
