How du i make a setup for my e-commerce like Unsplash
Hi, I want a setup like Unsplash for my Shopify Store https://journeyli.co/.
I want www.journeyli.co/blog/ to be a Ghost.io blog like it is for Unsplash.
How do I set that up, and isn’t it correct, that this is the best solution for SEO?
Thanks in advance!
Best regards,
Martin Bjørn
You can not.
Shopify web server is solely managed by them, so you can’t configure the subdirectory of your domain to use other applications. Another alternative is to make your blog on a subdomain. Then just simply link it from Shopify.
– Wibi
