Hello! I’m trying to use the bookmark function to link to several other stories within a story. When adding three bookmarks, they are all the same size in the editor, but when the post is previewed, the first bookmark is a significantly smaller size than the other two. I’ve tried re-ordering the bookmarks, resizing the header image and adding a different content link, and that has not resolved the issue. Does anyone have any suggestions?
Could you provide a preview link? It would be easier to debug with a link.
You can share a preview link without publishing the post, as shown in the image below:
The variation in bookmarks’ width is due to the theme not having a specific width set for them.
You can fix it by put the following into Ghost settings => Code injection => Site header
<style>
.post-content .kg-bookmark-card {
width: 100% !important;
</style>
Looks like that did the trick!! Thank you so much ![]()
