Bug: Fix undo with HTML blocks
If you have an HTML block with some html code in it, you make changes to it, then hit CTRL+S it will save. Then select the block and delete it. If you press CTRL+Z it will undo, but the block will return with old content from some random earlier save point, not the most recent save you just did.
It seems like a lot of users are having issues with this.
The issue is being tracked here Undo after deleting a card can lose card contents · Issue #10049 · TryGhost/Ghost · GitHub
Thanks :slight_smile:
