Bug or bizaree behavior with tier pricing?
Fill out the following bug report template with as much detail as possible!
Are you sure this is a bug? If you just need help, post in the developer help category. If it’s a feature request, head to the ideas category.
Issue Summary
Trying to update a subscription tier to $18.99. When I do this, I cannot save the tier. I click save, it won’t save. If I leave the page it’s not saved. If I set the price ti $18 flat or $19 - it saves and works fine. $18.99 won’t work (USD).
$199.99 for yearly works just fine.
Steps to Reproduce
  1. Setup a tier. Set the price to $18.99 a month and save
sent a video of this behavior to support but curious if anyone else has seen it?
Thanks for sharing this. It does seem like a bug. I’ve filed a report with the team and will keep you posted on the investigation/fix!
thanks - and again typing and typing so I hit 20 characters and can post
Bug confirmed. It has to do with rounding/precision of decimal numbers. The engineering team are investigating it, and I’ll follow up when we release a fix.
