In the ghost admin,i can not upload the image,please help me??
It tell me:
“Internal server error, cannot upload image.”
i had tried it more times,no effect.
It tell me:
Where are you hosted? Do they impose an upload limit?
That’s odd. Is it only that image? If you reload the page, does the problem persist?
I am not hosting anything. I am using Ghost Pro.
Yes the problem persists if I reload. I can upload normal images of formats png, jpg, svg etc.
The same thing happens to me. In my case SelfHosted. It has to be a bug in the latest versions. I hope they fix it.
I tried with different gif images of different sizes. It is not about the size. Some gif images just do not work with Ghost for whatever reason. One example is the one above (feel free to try yourself).
Is this something that can count as a GitHub issue/bug report? If so, I can open one.
