Can't copy/paste into Ghost editor
Setup information
Ghost Version
6.19.3-ynh1
Node.js Version
18.2.4
How did you install Ghost?
YunoHost Ghost package.
Self-hosting at home on an HP mini PC, with YunoHost.
Database type
MariaDB
Browser & OS version
Arc 1.136.0 (75750) | Chromium Engine 145.0.7632.117
________________________
There’s an older relevant thread where it seems like someone did solve this issue, but unfortunately it’s too old to respond to, in order to ask for clarification. I can’t figure out what’s blocking me from pasting from my clipboard into the Ghost editor – either content from the editor or copied from elsewhere. I’ve been able to successfully paste into other components of the app (Mailgun API key, excerpt block, etc), so I’m just uncertain of what might be the obstruction.
My domain is from Cloudflare, but I’m not using any proxy services outside of a simple DNS configuration. Is there a security setting in the Ghost config that I need to adjust?
Anything in the console logs when you try? And if you try a different browser, any changes?
So, it works as expected in both Safari and Firefox, which made this an Arc/Chromium issue. I went through my extensions, and found that TamperMonkey was the culprit!
Peculiar, since I don’t have this issue with any of the other Ghost instances I work with, so I’ll have to dig deeper into what makes this one so special :upside_down_face:
How do you like Ghost with MariaDB? Dies it not scream at you? Lol
Gonna level with you: I am not in the weeds like that, so it is completely indistinguishable to me from an “original recipe” build so far. There may come a day when it introduces some issues, and the YunoHost folks make that clear, but they seem to be quite good about keeping their updates in step with the official build.
