I have several ghost instances running on a DO droplet. One of them is acting up.
Ghost-CLI version: 1.13.1
Ghost version: 3.3.0
On ghost start I get this
+ sudo systemctl is-enabled ghost_huldrahuseierforening
✖ Starting Ghost: huldrahuseierforening
An error occurred.
Message: 'Command failed: /bin/sh -c sudo -S -p '#node-sudo-passwd#' systemctl is-enabled ghost_huldrahuseierforening
linked
OS: Ubuntu, v16.04.6 LTS
Node Version: v10.15.3
Ghost Version: 3.3.0
Ghost-CLI Version: 1.13.1
Environment: production
Command: 'ghost start
The instance starts, but it is annoying to get this error. I have re-installed the instance, but the error prevails, and only for that instance, and only for the start command.
The is-enabled output is different for this instance, returning linked instead of enabled
$ sudo systemctl is-enabled ghost_huldrahuseierforening
linked
$ sudo systemctl is-enabled ghost_intergate
enabled
I suspect the issue is with the ghost user from ghost setup linux-user, and permissions.
Any help appreciated.
Cheers!
