I have previously. purchased a host. Zinger domain a while ago and I would like to use it with Ghost. When I try to Add it as a custom domain and verify it says Unable to detect a valid CNAME record for ( ***********.pro) Is this possible to use with ghost?
You should be able to use any domain with Ghost, as long as you can edit the DNS.
Sometimes you just need to try a couple hours later, because DNS may have the old value cached. If that doesn’t work, you may want to contact support directly to have a look.
ok thank you
