- What’s your URL? bilgi.wiki
- What version of Ghost are you using? latest version
- What configuration? default
- What browser? chrome
- What errors or information do you see in the console? Connection timed out , ERR_CONNECTION_TIMED_OUT
I have successfully installed on my ubuntu vps server.
I also set Full (strict) from cloudflare settings.
It doesn’t open when I go to bilgi.wiki/ghost.
✔ Checking system Node.js version - found v16.19.0
✔ Checking logged in user
+ sudo systemctl is-active ghost_bilgi-wiki
? Sudo Password [hidden]
Instance is currently running
ℹ Validating config [skipped]
✔ Checking folder permissions
✔ Checking file permissions
✔ Checking free space
✔ Checking systemd unit file
✔ Checking systemd node version - found v16.19.0
