Customize sign up text
Screenshot 2022-03-19 at 12.34.42
How can I change this default text: “Don’t miss out on the latest issues. Sign up now to get access to the library of members-only issues.”?
I don’t know what to look for.
You’ll need to edit the relevant .hbs file for the theme, and re-upload. The file can vary according to the theme you use.
Since you are using the Journal theme you need to change the text in the theme itself.
I’m going to assume you know how to download a theme on Ghost and open it on Visual Studio Code (or another text editor), so I won’t give instructions about that.
The theme file you want to change is called default.hbs
Then look at line 57. Change the text inside the div the to text you want.
See the screenshot below.
