I am at a loss as to why changes I made in a theme run perfectly fine on my dev machine but not in prod. Both ghost instances are running ghost 5.59.1. Anyone have any ideas what I might be doing wrong? Below are some differences with the environments…
Prod
- node 16.2.2
- mysql8
- did not install yarn, gulp as I assume I don’t need to
Dev
- node 18.17.1
- sqlite3
- installed yarn, gulp
There are super minor changes to the index and loop HBS files associated with the Ghost Dawn template; eg show 2 weeks of posts on the homepage and hide the load more paginate button.
I have GitHub setup to push committed changes to prod but noticed the changes I made don’t render on Prod. In fact, content on the homepage content feed is blank (eg the loop isn’t working.) So, then I ran yarn zip to compile a dist archive and manually upload to prod. Same thing, changes don’t show on prod, homepage content feed is blank. I’ve tried restarting the server, made no difference.
Here’s index.hbs – the original code vs my changes
Original Code
{{!< default}}
<main class="site-main">
<div class="post-feed gh-feed gh-canvas">
{{#foreach posts}}
{{> "loop"}}
{{/foreach}}
</div>
{{pagination}}
</main>
My Changes
{{!< default}}
{{#get "posts" filter="published_at:>'2 weeks ago'" limit="all"}}
{{#foreach posts}}
{{> "loop"}}
{{/foreach}}
{{/get}}
</div>
</main>
Here’s loop.hbs – with original code vs my changes
Original code
<article class="feed {{visibility}} {{post_class}}">
<div class="feed-calendar">
<div class="feed-calendar-month">
{{date published_at format="MMM"}}
</div>
<div class="feed-calendar-day">
{{date published_at format="DD"}}
</div>
</div>
<h2 class="feed-title">{{title}}</h2>
<div class="feed-right">
{{> "icons/star"}}
<div class="feed-length">
{{reading_time}}
</div>
</div>
{{> "icons/chevron-right"}}
<a class="u-permalink" href="{{url}}" aria-label="{{title}}"></a>
</article>
My changes
</div>
</div>
</div>
<div class="feed-tags">
{{#foreach tags}}
<a href="{{url}}" class="tag">{{name}}</a>
{{/foreach}}
</div>
{{> "icons/star"}}
{{reading_time}}
</div>
</div>
</article>
