How do I get utteranc.es (GitHub Issues based comments engine) to work on a Ghost blog? Any tutorial for the same?
1.) Where should I add the utteranc.es script (see below) if i want the comments engine framework appear in every blog post but not in pages like HOME, ABOUT US?
Thank you for your reply .
Will [utteranc.es](http://utteranc.es) work on a statically generated (using buster) ghost blog and hosted on GitHub Pages or will it only work if ghost is deployed on a live server (like AWS EC2) ?
Hi Cathy, Thanks for your feedback. Based on your last reply, I was searching for some tutorial online on how to add this utteranc.es to a ghost blog post and I came across this - Add comments with utterances
What I don’t understand from this tutorial is:
1.) When I searched in my Finder the local ghost folder for utils, I only see many results showing utils.js and not utils.jl ! Where is the utils.jl file in the ghost local folder structure to add this hfun_* function ? Do you think utils.jl was a typo in the blog?
2.) Is hfun_* represents some special class of functions belonging to hfun, and the * after the hfun_ means any name could follow like hfun_addcomments() ?
Would greatly appreciate if you could kindly assist or clarify this small issue.
