Discord webhook not working
Issue Summary
  • No notification is sent in Discord despite setting up Discord webhook in Ghost integrations
  • when using a slack webhook, it seems to work
Steps to Reproduce
  1. Create webhook in Discord server
  2. Paste webhook URL in Ghost Integrations > Slack
  3. Send test notification
Setup information
Ghost Version
5.22.9
Node.js Version
v16.15.0
How did you install Ghost?
DigitalOcean Droplet, using instructions in app marketplace
Ubuntu 20.04. LTS
Database type
MySQL 8
Relevant log / error output
{"name":"Log","hostname":"...","pid":769280,"level":50,"err":{"id":"ab54b730-6041-11ed-b991-7998a8a29648","domain":"...","code":null,"name":"InternalServerError","statusCode":500,"level":"critical","message":"The server has encountered an error.","context":"\"The slack service was unable to send a ping request, your site will continue to function.\"","help":"\"If you get this error repeatedly, please seek help on https://ghost.org/docs/.\"","stack":"HTTPError: Response code 400 (Bad Request)\n    at /var/www/ghost/versions/5.22.9/core/server/services/slack.js:147:27\n    at EventEmitter.<anonymous> (/var/www/ghost/versions/5.22.9/node_modules/got/source/as-promise.js:74:19)\n    at processTicksAndRejections (node:internal/process/task_queues:96:5)","hideStack":false},"msg":"The server has encountered an error.","time":"2022-11-09T15:17:48.198Z","v":0}
At the end of your webhook URL, try adding /slack.
It’ll then look like this: https://discord.com/api/ .... /slack
Thank you, this worked like a charm :+1:
This worked for me as well. tks
