Hi! I’ve deployed an instance of Ghost for publishing my articles, thoughts and other stuff, and I’m trying to configure some triggers to execute some automations on n8n. The point is that all the triggers from Ghost produces the same warning message:
Oh, damn! It was my fault! I’ve my n8n instance secured behind a reverse proxy with basic auth… Thanks for this tip, that’s help me find the problem. Sorry for this mistake.
Didn’t want to open a new thread, but I have a similar problem. I’m trying to get a “new member” webhook working with Mattermost platform.
I have already working webhooks towards that platform, but can’t seem to get Ghost webhooks to work.
When testing with webhook.site, there are no errors just a nice JSON content. Also, testing my webhook URL via a simple CURL with --data I also get hits.
On top of this, when testing via Zappier, it all works fine so I am using that as a workaround atm. But, I would really like to get to the bottom of this as I can’t see any problems on the destination or source logs (docker logs) that might point me in the right direction.
Haven’t had this configured before, so not sure what the usual suspects might be. Just wanted to point out that none of the actions work, not just add new member.
I’m facing the same issue. My n8n installation sits behind a Cloudflare tunnel, and the webhook is returning me the same error when trying to send the webhook to my installation.
I’ve tested the webhook with postman, and it works without anything strange in the response.
using the n8n webhook there is an error in the ghost log saying
Triggereing n8n webhook via browser works … no cloudlfare authentification required at all … so thats seems not the blocking issue.
[2024-07-17 10:16:00] WARN Request to https://mydomain.de/webhook-test/6f7b288e-1efe-4504-a6fd-660931567269 failed because of: ERR_NON_2XX_3XX_RESPONSE.```
That error would suggest the webhook is receiving back a 400/500 level response. Those can be server errors, or authentication problems.
Do you have logging on the server that’s supposed to catch the webhook? Does it receive the request?
If the request doesn’t reach the destination server, look at cloudflare - that 400/500 status code is probably an authentication failure / bouncing bots / etc.
If the request reaches the destination server, look for what specific error that server is returning. It’s possible that cloudflare is stripping off a required header, but your logs should tell you more.
