Hi all,
I’m running Ghost on Docker using the official docker image. I’m trying to set it up so the CSS updates.
When I run yarn dev in the themes directory, I get this message:
root@0fc752782729:/var/lib/ghost/content/themes/ease# yarn dev
yarn run v1.22.5
warning ease@1.0.0: The engine "ghost" appears to be invalid.
warning ease@1.0.0: The engine "ghost-api" appears to be invalid.
$ gulp
Error: Cannot find module 'pump'
Require stack:
- /var/lib/ghost/content/themes/ease/gulpfile.js
- /var/lib/ghost/content/themes/ease/node_modules/gulp-cli/lib/shared/require-or-import.js
- /var/lib/ghost/content/themes/ease/node_modules/gulp-cli/lib/versioned/^4.0.0/index.js
- /var/lib/ghost/content/themes/ease/node_modules/gulp-cli/index.js
- /var/lib/ghost/content/themes/ease/node_modules/gulp/bin/gulp.js
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
at Function.Module._load (internal/modules/cjs/loader.js:667:27)
at Module.require (internal/modules/cjs/loader.js:887:19)
at require (internal/modules/cjs/helpers.js:74:18)
at Object.<anonymous> (/var/lib/ghost/content/themes/ease/gulpfile.js:2:14)
at Module._compile (internal/modules/cjs/loader.js:999:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
at Module.load (internal/modules/cjs/loader.js:863:32)
at Function.Module._load (internal/modules/cjs/loader.js:708:14)
at Module.require (internal/modules/cjs/loader.js:887:19) {
code: 'MODULE_NOT_FOUND',
requireStack: [
'/var/lib/ghost/content/themes/ease/gulpfile.js',
'/var/lib/ghost/content/themes/ease/node_modules/gulp-cli/lib/shared/require-or-import.js',
'/var/lib/ghost/content/themes/ease/node_modules/gulp-cli/lib/versioned/^4.0.0/index.js',
'/var/lib/ghost/content/themes/ease/node_modules/gulp-cli/index.js',
'/var/lib/ghost/content/themes/ease/node_modules/gulp/bin/gulp.js'
error Command failed with exit code 1.
info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
Thank you in advance for your reply
-TrainerGamer
