I am having errorr importing wp2ghost.json to Ghost. Only Import fails was shown and no other error message was shown. The Wordpress sites contain posts written in Myanmar. Is this can be the cause of fail import ?
Are you importing from WP to ghost 2.x? Because you can only import to Ghost 1.x at this moment. Then update the ghost installation to 2.x after import.
No I’m using 1.3. I also update the Wordpress plugin code a bit because it is return the empty json file. I found out this is because of substr in the plugin. So, I remove the substr function around title and it return json file with data. But when I tried to import in ghost, import failed and no error message was shown.
