I’ve this error when installing ghost:
Aug 19 02:05:12 instance-1 node[10480]: message: {
Aug 19 02:05:12 instance-1 node[10480]: statusCode: 500,
Aug 19 02:05:12 instance-1 node[10480]: errorType: ‘MigrationScriptError’,
Aug 19 02:05:12 instance-1 node[10480]: level: ‘normal’,
Aug 19 02:05:12 instance-1 node[10480]: message: ‘Field length of customer_id in members_stripe_customers is too long!’,
Aug 19 02:05:12 instance-1 node[10480]: id: 300,
Aug 19 02:05:12 instance-1 node[10480]: context: ‘This usually happens if your database encoding is utf8mb4.\n’ +
Aug 19 02:05:12 instance-1 node[10480]: ‘All unique fields and indexes must be lower than 191 characters.\n’ +
Aug 19 02:05:12 instance-1 node[10480]: ‘Please correct your field length and reset your database with knex-migrator reset.\n’,
how to fix this please?
OS: debian 10, Ver 15.1 Distrib 10.1.45-MariaDB
Thanks
