Ghost faild to upgrade
Ghost field to upgrade, so i tried to force the upgrade, unfortunately i got this error!! any help…?
this is the error…
OS: Ubuntu, v22.04.2 LTS
Node Version: v18.16.0
Ghost Version: 5.45.0
Ghost-CLI Version: 1.24.0
Environment: production
Command: ‘ghost update 5.45.0 --force’
Message: Ghost was able to start, but errored during boot with: alter table post_revisions add feature_image_caption varchar(65535) null, algorithm=copy - Column length too big for column ‘feature_image_caption’ (max = 16383); use BLOB or TEXT instead
Help: Error occurred while executing the following migration: 2023-04-21-13-01-add-feature-image-meta-to-post-revisions.js
Suggestion: journalctl -u ghost_mrsoso-com -n 50
Stack: Error: Ghost was able to start, but errored during boot with: alter table post_revisions add feature_image_caption varchar(65535) null, algorithm=copy - Column length too big for column ‘feature_image_caption’ (max = 16383); use BLOB or TEXT instead
at Server. (/usr/lib/node_modules/ghost-cli/lib/utils/port-polling.js:73:28)
at Object.onceWrapper (node:events:627:28)
at Server.emit (node:events:513:28)
at emitCloseNT (node:net:2135:8)
at process.processTicksAndRejections (node:internal/process/task_queues:81:21)
when i ty to upgrade i see this
  • sudo systemctl is-active ghost_mrsoso-com
    :heavy_check_mark: Checking system Node.js version - found v18.16.0
    :heavy_check_mark: Ensuring user is not logged in as ghost user
    :heavy_check_mark: Checking if logged in user is directory owner
    :heavy_check_mark: Checking folder permissions
    :heavy_check_mark: Checking file permissions
    :heavy_check_mark: Checking content folder ownership
    :heavy_check_mark: Checking free space
    :heavy_check_mark: Checking for available migrations
    :heavy_check_mark: Checking for latest Ghost version
    All up to date!
My current version is 5.44.0 and im trying to upgrade to 5.45.0
by running this cmd: ghost check-update. i see:
Current version: 5.44.0
Latest version: 5.44.0
You’re up to date!
I’ve moved your posts to #help since this isn’t a bug.
To check for an update use…
ghost check-update
…and the current response is…
https://careers.ghost.org
Current version: 5.43.0
Minor update available!
There is no 5.45 release!
but on GitHub the latest version is 5.45.0 not 5.44.0 !!
so if ur getting 5.44.0 that means my setup is fine, nothing is wrong and its a bug in ghost as it should return 5.45.0 instead of 5.44.0
any update?? … as this is clearly a bug…
npm and github say that there is a 5.45.0
I’m a Ghost user, just like you. My guess is that updates are first released to Ghost(Pro) before general release. However, this is a minor release, so I don’t see the urgency. Moreover, it was only released three days ago.
The Ghost dashboard will inform you when the update is available, or simply check with ghost check-update.
Even though the release was published to GitHub, it was not published to NPM due to test failures (which is a good thing).
yea i noticed, and i had to rebuild the current version…!
thx for confirmation brother :)
i just thought that something is wrong with my setup that’s all :)
v5.45.1 was released a few mins ago, try updating again :slight_smile:
problem solved, thx :)
